Demandbase Ads is a premium advertising cloud platform. It helps B2B companies reach the right accounts with tailored messages.
This video demonstrates creating a Demandbase Ads connection.
After you start the connection , you have to configure it in the Create connection panel and must complete all of the required * authentication settings:
API key * |
Enter your Demandbase Ads API token. Multiple layers of protection, including AES 256 encryption, are in place to keep your API token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Demandbase Ads account.
Navigate to Settings > My profile > API tokens.
Click Generate token.
Click Copy to clipboard.
