Instagram helps users to advertise their business and reach the next customers with precise targeting and actionable insights.
This video demonstrates creating an Instagram connection.
After you start the connection, you have to configure it in the Create connection panel and must complete all of the required * authentication settings:
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Instagram ads.
To add an OAuth 2.0 client and configure your credentials, click the plus ( + ) button. Click the edit ( |
Scopes * |
Scopes are OAuth 2.0 permissions that the Instagram Ads API defines to limit access to your account. |
Sign in to your Facebook developer account.
Navigate to My apps.
Click Create app. For more information, see Create an app.
From Select an app type, select Business, and Click Next.
Enter Appname and App contact email.
Select Business account.
Read the Policies and click Create app. You will be navigated to the created app page.
Navigate to Settings > Basic.
Copy App ID.
Copy App secret.
Click Save.
From Add products to your app, select Instagram graph API, and click Set up.
Name (required): Enter the required iClient name.
Client ID (required): Enter client ID (retrieved from the above section).
Client secret (required): Enter client secret (retrieved from the above section). Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s client secret safe. When editing the iClient at any point, you must enter the secret value again; it is stored only when the connection is saved and never displayed as text.
Click Save.
