The Suppliers template is a purpose-built integration, designed for the Celigo integrator.io iPaaS. This template automates the most common use cases to enable fully digital supplier collaboration capabilities by integrating the SAP Business Network Commerce Automation with NetSuite. It eliminates the overhead associated with dual-entry and maintenance between multiple systems.
This Quickstart template contains prebuilt flows that can be configured and deployed without coding or IT support. In addition to the OOTB functionality, the template can be customized and enhanced, according to your unique requirements. (See also SAP Business Network Commerce Automation – NetSuite template for Buyers.)
SAP Business Network Commerce Automation - NetSuite quickstart template features & benefits
- Optimize procurement and supplier operations by automatically updating orders and invoices in real-time
- Gain total visibility into the supply chain by automating the procurement process with real-time, ongoing, two-way supplier communication
- Stay in compliance by improving data accuracy, minimizing wrong or duplicate payments, and enhancing accounting processes and overall financial visibility
- Reduce maintenance time with an interactive dashboard for sophisticated error handling and integration support
- Efficiently scale operations by automating processes that rely on the SAP Business Network Commerce Automation and NetSuite platforms
- Take control of your integrations with tools that let you configure and make mapping changes on the fly
Supported integration flows
The following four built-in flows sync from the specified source data to the corresponding destination:
NetSuite to SAP Business Network Commerce Automation
| Flow | What’s not supported |
| NetSuite invoices to SAP Business Network Commerce Automation invoices |
| NetSuite item shipments to SAP Business Network Commerce Automation ship notices | – |
| NetSuite sales order confirmations to SAP Business Network Commerce Automation purchase order confirmations |
SAP Business Network Commerce Automation to NetSuite
| SAP Business Network Commerce Automation purchase orders to NetSuite sales orders |
Error handling
Most integrator.io error messages will clearly explain the error and suggest troubleshooting methods. If you are unsure of what the error means, contact Celigo support.
For errors passed through from SAP Business Network Commerce Automation or NetSuite, see the respective endpoint documentation.
