Payout to reconciliation Automation for NetSuite release notes, 2023.1.1
What’s enhanced
Transaction amount multiplier
The Transaction amount multiplier setting has been added to the Stripe payout to NetSuite payout custom record flow that allows you to set the multiplier value for both decimal and zero-decimal currencies to calculate the settlement value for payout transactions.
  • For decimal currencies like USD, enter a value of 0.01. To get the settlement value, the transaction amount in the currency’s smallest unit is multiplied by the entered value. To get the value of USD 11.50, 1150 cents is multiplied by 0.01.
  • For zero-decimal currencies like JPY, enter a value of 1 as zero-decimal currencies have no decimal values. The transaction amount is multiplied by 1 to get the settlement value. To get the value of ¥500, the amount value of 500 is multiplied by 1.
The default value of 0.01 will be considered if you do not enter the multiplier value.
For more information, see Reconcile your Stripe payouts.
