Clearbit is a data activation platform that helps B2B teams understand customers, identify prospects, and personalize interactions with real-time intelligence.
This video demonstrates creating a Clearbit connection.
API type * |
Choose the API type,depending on the Clearbit API type you're connecting to. The settings then become specific to the selected API type. |
Auth type * |
Select your connection’s authentication type (Basic or Token). |
API key * |
Enter your Clearbit API key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
The following table shows the API type and their specific settings
API type |
Person API |
Email * |
Enter your Clearbit account email ID |
Company API and Prospector API |
Domain * |
Enter your company’s domain. For example, |
Discovery API |
Query * |
Enter your query. For example, |
Risk API |
Email * |
Enter your Clearbit account email ID. |
Risk API and Reveal API |
IPv4 address to lookup * |
Enter your IPv4 address. For example |
Autocomplete API |
Name * |
Enter your company’s name. |
