Set up a connection to Listrak
Listrak is a digital marketing automation platform that helps you with email marketing, mobile messaging, customer insights, and cross-channel orchestration.
This video demonstrates creating a Listrak connection.
Setting
Instructions
Name your connection *
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Listrak.
To add an OAuth 2.0 client and configure your credentials, click the plus ( + ) button. Click the edit ( pencil.svg ) button to modify a selected OAuth 2.0 client.
dataLoad.svg​​ Create an OAuth 2.0 iClient resource
Scopes *
Scopes are OAuth 2.0 permissions that Listrak defines to limit access to your account.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the OAuth 2.0 auth universal connector documentation.
  1. Sign in to your Listrak developer account.
  2. Navigate to Integrations > Integrations management.
  3. Click New Integration > Setup.
  4. Enter your Integration name.
  5. Select Access levels and check Disable IP address whitelist .
  6. Click Save and Confirm.
  7. Click Setup.
  8. Copy the Client ID.
  9. Copy the Client secret.
How to configure scopes
  1. Click Scope.
    – or –
  3. Click Save.
Additional references
