Splunk is a data platform that helps for expansive data access, powerful analytics, and automation in real-time.
| Setting | Instructions |
| Name your connection * |
| Subdomain * |
Enter your Splunk subdomain. For example, if your Splunk account is located at
| Auth type * | Select Token as the authentication type for this connection (the basic auth option is described separately). |
| Token * |
Enter your Splunk token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token universal connector documentation.
- Sign in to your Splunk account.
- Navigate to Settings > Users and authentication > Tokens.
- Click New token.
- Copy Token.
