Set up a connection to Trello
Trello is a project management application that allows individuals and teams to organize and track their work using visual boards, lists, and cards.
This video demonstrates creating a Trello connection.
Setting
Instructions
Name your connection *
Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections you’ve created.
API key *
Enter your Trello API key.
When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Token *
Enter your Trello token.
dataLoad.svg​​ How to retrieve the token
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Custom auth universal connector documentation.
How to retrieve the API key and token
  1. Sign in to your Trello account.
  2. Navigate to Admin page, read, and acknowledge the privacy and compliance terms.
  3. Click New.
  4. Provide the required details and click Create. The API key page opens.
  5. Click Generate a new API key. Read the terms and click Generate API key.
  6. Copy the API key.
  7. Click Token which is next to the API Key. Read the message and click Allow.
  8. Copy the Token.
    trello
Additional references
