JumpCloud is a cloud-based directory service that provides centralized user management and authentication for IT networks and resources.
| Setting | Instructions |
| Name your connection * |
| Region * | Select your JumpCloud account region (Europe, India, or United States). For detailed information, see Login URLs. |
| API key * |
Enter your JumpCloud API key. For detailed information on retrieving the API key, see API keys. Multiple layers of protection, including AES-256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Token universal connector documentation.
