Pendo is a product-analytics application that helps companies understand their customers better by gathering insights from product interaction.
| Setting | Instructions |
| Name your connection * |
| API type * |
Choose your Pendo API type you're connecting tool. The settings then become specific to the selected API type. |
| Token * |
Enter your Pendo engage API token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
- Sign in to your Pendo developers account.
- Navigate to Settings > Integrations > Integration keys.
- Click + Add integration key.
- Enter the description.
- If required, check Allow write access.
- Click Create.
- Copy API key.
| Token * |
- Navigate to Subscription settings > Choose your app.
- Under App details, click Show.
- Copy Track event shared secret.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token universal connector documentation.
