Set up a connection to Salsifys
Salsify is a comprehensive solution provider that allows customers to take control of their digital shelves.
The Salsify connector is in BETA and may be subject to changes.
Setting
Instructions
Name your connection *
API type *
Choose your Salsify account API type:
  • Salsify V1: Access core Salsify platform capabilities using the original REST endpoints for legacy integrations.
  • Salsify: Manage product content, digital assets, syndication, and workflows using the current REST APIs.
  • SXM: Deliver and manage rich product experiences across channels using Salsify Experience Manager APIs.
API type: Salsify V1
Setting
Instructions
Organization ID *
Enter your organization ID.
For example, if your Salsify account is located at https://app.salsify.com/app/orgs/s-a3326-0ac-4de-972-c436063303cf/productsthen s-a3326-0ac-4de-972-c436063303cfis the organization ID.
Auth type *
Select your Salsofy account authentication type (Token or OAuth 2.0).
Auth type: Token
API key *
Enter your Salsify API key.
dataLoad.svg​​ How to retrieve API key
Auth type: OAuth 2.0
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Salsify. For more information, see Create an OAuth Application.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit (pencil.svg ) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource
API type: Salsify
Setting
Instructions
Organization ID *
Auth type *
Auth type: Token
API key *
OAuth 2.0 client *
API type: SXM
Setting
Instructions
OAuth 2.0 client *
  1. Sign in to your Salsify developer account.
  2. Navigate to My profile > API access.
  3. Click Show API key. The Get API key window appears.
  4. Enter your Password.
  5. Click Ok.
  6. Copy the API key.
How to retrieve the client ID and client secret (SXM)
  1. Sign in to your Salsify SXM account.
  2. Navigate to Profile > API credentials.
  3. Click Create new API credentials.
  4. Enter a Name.
  5. Click Create.
  6. Copy the Client ID.
  7. Copy the Client secret.
Additional references
