Docparser is cloud-based document data extraction tool that helps to identify and extracts data from Word, PDF, and image-based documents using zonal OCR technology and advanced pattern recognition.
This video demonstrates creating a Docparser connection.
Auth type * |
Select Basic as the authentication type for this connection (the token option is described separately). |
API key * |
Enter your Docparser API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your authentication key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see basic universal connector documentation.
Sign in to your Docparser developer account.
Navigate to API > REST API credentials.
Click Copy to clipboard.
