Set up a connection to Azure AI Document Intelligence
Azure AI Document Intelligence is a cloud-based artificial intelligence (AI) service provider designed to extract valuable information from structured and unstructured documents, such as forms, invoices, receipts, and other business documents
This video demonstrates creating an Azure AI Document Intelligence connection.
After you start the connection, configure it in the Create connection panel and complete all of the required * authentication settings.
Setting Instructions
Name your connection * Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections you’ve created.
Subdomain *
Enter your Azure AI Document Intelligence Subdomain.
Fetch data How to retrieve subdomain
API Key *
Enter your Azure AI Document Intelligence key 1.
Multiple layers of protection, including AES 256 encryption, are in place to keep your authentication token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Fetch data How to retrieve API key and region
Region * Select your Azure AI Document Intelligence region.
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding token settings, see token universal connector documentation.
  1. Sign in to your Azure account.
  2. Click Create to create an AI Documentation. For more information on how to create a Form Recognizer, see Create an AI Document Intelligence resource.
  3. Navigate to All services > Documentation Intelligences and select the required form recognizer.
  4. Navigate to Resource management > Keys and endpoint.
  5. From the Endpoint, copy subdomain.
  5. Copy Key 1.
  6. See Location/region.
azure
Additional references
Was this article helpful?
0 out of 0 found this helpful
