Nimble is a social customer relationship management (CRM) software that helps businesses manage their customer interactions, track leads and deals, and improve their relationships with customers.
This video demonstrates creating a Nimble connection.
Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections you’ve created. |
API token * |
Enter your Nimble API token. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding Token settings, see token universal connector documentation.
Sign in to your Nimble account.
Navigate to Settings > API tokens.
Click Generate new token.
Enter the Description and click Generate.
Copy API token.
