Set up a connection to Pinecone
Pinecone is a vector database that makes it easy to build high-performance vector search applications.
This video demonstrates creating a Pinecone connection.
Setting
Instructions
Name your connection *
API type *
Choose the API type, either Vector operations or Index operations depending on the Pinecone API type you're connecting to. The settings then become specific to the selected API type.
Environment *
Enter your Pinecone account environment. For example, us-east1-gcp.
Index name project ID *(This setting is visible only when you select the vector operations API type)
Enter your index project ID. For example, if your index name is index-123456.svc.us-west-gcp.pinecone.io, then index-123456 is your project ID.
dataLoad.svg​​ How to retrieve the index project ID
API key *
Enter your Pinecone API key.
How to retrieve index ID
  1. Sign in to your Pinecone account.
  2. Navigate to Project > Indexes.
  3. Click + Create index.
  4. Enter the index Name and Dimension.
  5. Select the Metric and Pod type.
  6. Click Create index .
How to retrieve API key and environment
  2. Navigate to Project > APIkeys.
  3. Click + Create API key.
  4. Enter API key Name.
  5. Click Create key.
  6. Copy API key .
  7. Copy Environment.
