RabbitMQ is a popular open-source message broker that enables the integration of various systems and applications by facilitating asynchronous communication between them.
This video demonstrates creating a RabbitMQ connection.
Instance URL* |
Enter the instance URL of your RabbitMQ server. For example, if your local host is Since integrator.io ignores all HTTP requests from a local host, you must create a secured tunnel to your local host and then generate an instance URL. The default management port is 15672, and “api” is the common path for API endpoints. |
Username* |
Enter your RabbitMQ account username. |
Password* |
Enter your RabbitMQ account password. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see basic universal connector documentation.
