Set up an OAuth 1.0 connection to Magento 2
Magento is an open-source e-commerce platform that offers features such as order management, business intelligence, and shipping.
Magento 2 documentation: API guide , Authentication
A. Set up a Magento 2 connection
Start establishing a connection to Magento 2 in either of the following ways:
    – or –
In the resulting Application list, select Magento 2.
The Create connection panel opens with the required and advanced settings.
B. Provide required Magento 2 application details
At this point, you’re presented with options for providing Magento 2 authentication.
Authentication type (required): Select OAuth 1.0 as the authentication type for this connection (the token option is described separately).
Base URI (required): Enter the base URI of your Magento 2 account. You can locate this URL in the address bar after you sign in to your Magento 2 account. For example, if your account is located at http://123.12.12.1/xyz/admin, then replace admin with rest and enter the base URI as http://123.12.12.1/xyz/rest.
Signature method (required): Select the required method to sign the API call:
  • HMAC-SHA1
  • HMAC-SHA256
  • HMAC-SHA512
  • RSA-SHA1
  • RSA-SHA256
  • RSA-SHA512
  • PLAINTEXT
Consumer key (required): Enter your consumer key. The consumer uses this value to identify itself to the service provider. This is enabled and required for all the Signature methods.
Consumer secret (required): Enter your consumer secret. The consumer uses this password to establish ownership of the consumer key. This is enabled and required when Signature method is HMAC-SHA1, HMAC-SHA256, HMAC-SHA512, or PLAINTEXT. Multiple layers of protection, including AES 256 encryption, are in place to keep your secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Access token (required): Enter the access token. The consumer uses this token to gain access to the protected resources on user's behalf. This is enabled and required for all the Signature methods. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Token secret (required): Enter the token secret. The consumer uses this secret to establish ownership of a provided token. This is enabled and required when Signature method is HMAC-SHA1, HMAC-SHA256, HMAC-SHA512, or PLAINTEXT. Multiple layers of protection, including AES 256 encryption, are in place to keep your secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Consumer private key (required): Enter the consumer private RSA key. This key is used to sign the API call request. This is enabled and required when Signature method is RSA-SHA1, RSA-SHA256, or RSA-SHA512
Realm (optional): Enter the realm value.
How to retrieve the consumer key, consumer secret, access token, and access token secret
  1. Sign in to your Magento 2 account.
  2. Navigate to System > Extensions > Integrations.
  3. Click Add new integration. For more information, see OAuth-based authentication.
  4. Enter a Name.
  5. Enter an Email.
  6. Enter the Celigo integrator.io Callback URL.
  7. Enter the Identity link URL.
  8. Enter your Magento 2 account password.
  9. Click Save and activate.
  10. In the API tab, add the required permissions.
  11. Click Allow. The Integration tokens for extension page opens.
  12. Copy the Consumer key.
  13. Copy the Consumer secret.
  14. Copy the Access token.
  15. Copy the Access token secret.
C. Edit advanced Magento 2 settings
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the Magento 2 connection.
Borrow concurrency from(optional): Select another connection from the list. By default, all data flowing through a connection record is submitted to the respective endpoint application at the Concurrency level configured for that connection record. There are cases, however, where multiple integrator.io connections need to share the same concurrency level, and this field allows you to specify which connection you would like to borrow from. With borrowed concurrency, the data flowing through both connections will be submitted to the endpoint application together, via a shared concurrency model.
Selecting another connection from the drop-down list changes the form. The concurrency level will be hidden, set to the same shared value as the other connection’s.
Auto-recover rate limit errors: This setting is enabled by default with a pre-defined value for Target concurrency level. You can disable the setting if required. To set or make changes in any of these settings, you must have administrator or manage permissions.
Target concurrency level: This field is shown only if Auto-recover rate limit errors is enabled. Change the predefined value as required to limit the number of concurrent API requests allowed by the connection resource. See also, Setting currency level on a connection.
Concurrency level: When Auto-recover rate limit errors is enabled, the Concurrency level cannot be edited and shows the concurrency level that the platform is currently using (runtime). When Auto-recover rate limit errors is not enabled, enter a value to limit the number of concurrent API requests allowed by the connection resource. See also, Setting currency level on a connection.
D. Test the connection
Once you have configured the Magento 2 connection, you have a few options for continuing:
  • Save & close – click to test and save the connection and exit the Create connection panel
