Storyblok is a headless content management system (CMS) that allows developers and content creators to manage and deliver content across various digital platforms. Its flexible and structured approach to content makes it a popular choice for building dynamic and personalized websites and applications.
This video demonstrates creating a Storyblok connection.
Region* |
Select your Storyblok region. If your URL is |
Token* |
Enter your Storyblok token. Multiple layers of protection, including AES 256 encryption, are in place to keep your authentication token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Storyblok account.
Navigate to My spaces > Add space.
Enter the name of your space.
Select Server location (Region).
Click Create space.
Navigate to Space actions > Access tokens.
Select the required Access level.
Enter Name.
Click Generate.
Copy the token.
