Jasper PIM is a product information management (PIM) system used to centralize, merchandise, and synchronize product data throughout the e-commerce business.
This video demonstrates creating a Jasper PIM connection.
Subdomain * |
Enter your Jasper PIM subdomain. For example, if your Jasper PIM account URL is |
API key * |
Enter your Jasper PIM API key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Jasper PIM account.
Navigate to Settings > API keys.
Click Create token.
Select User.
Enter Key name.
Click Create. The My API key message appears.
Copy the new API key.
If you do not copy your new API key, you cannot see the key again.
