Lattice is a cloud-based performance management solution that helps HR professionals manage employee productivity and progress.
API key * |
Enter your Lattice API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your authentication key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Lattice account.
Navigate to Admin > Organization > Settings > API keys.
Click Generate API key.
Click Copy.
If you do not copy your new API key, you cannot see the key again.
