Shopee is an e-commerce platform. It offers a wide variety of products and provides customers with easy, secure, and fast online shopping.
API type * |
Choose your Shoppe API type:
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided by Shopee.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Domain * |
Enter your Shopee account domain. For example, if your Shopee account instance URL is |
Valid domain names * (iClient setting) |
Enter the unique domain name for the OAuth URL. Separate multiple values with a comma. For example, if your URL is |
Partner ID * |
Enter your Shopee app partner ID (live or test depending on your account environment). |
Partner key * |
Enter your Shopee app partner key (live or test depending on your account environment). Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s partner key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
The following settings are applicable only to the API type Shop: |
Shop ID * |
Enter your Shopee shop ID. |
Authorization account type * (iClient setting) |
Select your Shopee account type (Main account or Shop account). |
Main account ID * (iClient setting) |
Enter your Shopee main account ID. |
The following settings are applicable only for Merchant API type: |
Merchant ID * |
Enter your Shopee merchant ID. |
Select your Shopee account type (Main account or Merchant account). |
Sign in to your Shopee open platform account.
Navigate to App management > App list.
Select the required application. For information on how to create an app, see App management.
Navigate to App key.
Copy Partner ID (live or test, depending on your account environment).
Click the Eye icon and copy Key (live or test, depending on your account environment).
Sign in to your Shopee Seller Central account.
Navigate to Product > My products > More.
Click Live preview.
From the product URL, copy the ID. For more information, see How do I check my shop ID.
