Rippling is a cloud-based workforce management platform that consolidates multiple back-office functions, including HR, IT, finance, payroll, benefits, and more into a single unified system.
API type * |
Choose your Rippling API type:
Environment * (This setting is visible only for the Legacy platform API type) |
Select your Rippling account environment:
Token * |
Enter your Rippling token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Rippling account.
Navigate to Company settings > API access.
Click Create API key.
Enter a Description.
Provide the required Permissions.
Click Save. You will be redirected to the API access page.
Copy the API token.
