AfterShip provides a world-class post-purchase experience through automated shipping, branded order tracking, proactive messaging, and seamless returns.
API type * |
Choose your AfterShip API type:
The following setting is common for all API types |
API key * |
Enter your AfterShip API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
The following setting is visible only for the Shipping and Commerce API types |
Environment * |
Select your AfterShip account environment type:
API key * |
AS store ID * |
Enter your AfterShip store ID. For detailed information on how to generate the store ID, See Create AS store ID. |
Sign in to your AfterShip account.
Navigate to Settings > API keys.
Click Create API key.
Enter a Name.
Select the API key as the Signature header.
Provide the API permissions as required.
Click Save.
Copy the API key.
