Sprout Solutions is payroll management software designed to simplify and streamline HR operations for businesses. It offers tools for payroll processing, employee self-service, and compliance management – enhancing efficiency and compliance for companies.
API type * |
Choose the API type, depending on the Sprout Solutions API type you're connecting to:
Environment * |
Select your Sprout Solutions account environment type.
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided by Sprout Solutions.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Subscription key * |
Enter your Sprout Solutions subscription key. Multiple layers of protection, including AES 256 encryption, are in place to keep your subscription key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
You will get an email from Sprout Solutions support instructing you how to retrieve the client ID and client secret. For more information, see Integrate with Sprout.
Sign in to your Sprout Solutions account.
Navigate to Profile > Subscriptions.
Click Show and copy the Primary key.
