Keka is a cloud-based HR management and payroll automation software.
Account type * |
Select your Keka account environment type:
Company * |
Enter your company name. |
Client ID * |
Enter your Keka client ID. |
Client secret * |
Enter your Keka client secret. Multiple layers of protection, including AES 256 encryption, are in place to keep your secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
API key * |
Enter your Keka API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Keka account.
Navigate to Settings > Integrations and automation > API access.
Copy the Client ID.
Copy the Client secret.
Click Create key.
Enter a Name, select the Expiry date, and the required Scopes.
Copy the API key.
