Personio is a cloud-based HR and applicant tracking software that offers a comprehensive suite of HR tools to manage employee data, recruiting, time tracking, and more, simplifying HR processes and compliance.
API type * |
Choose the Personio API type you're connecting to:
API type: Personnel data |
API version |
Select your Personio account API version (v1 or v2). |
Client ID * |
Enter your Personio client ID. |
Client secret * |
Enter your Personio client secret. Multiple layers of protection, including AES 256 encryption, are in place to keep your client secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
OAuth 2.0 client * (only for v2 APIs) |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Personio. To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
API type: Recruiting |
Token * |
Enter your Personio token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Company ID * |
Enter your Personio company ID. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Token universal connector documentation.
Sign in to your Personio account.
Navigate to Settings > Integrations > API credentials and click Create custom integration.
Enter a Name and click Next.
Check the Permissions and Attributes.
Click Create integration.
Copy the Client ID.
Copy the API secret (Client secret).
Click Finish.
Navigate to Settings > Integrations > API credentials.
Click Recruiting integrations.
Copy the Access token.
Copy the Company ID.
