Xactly Connect is a revenue platform that enables businesses to accelerate the digital transformation of their revenue operations.
Account type * |
Select your Xactly Connect account environment type:
Consumer * |
Enter your consumer name provided by the Xactly Connect support team. For more information on authentication, see Connect REST API Reference. |
Username * |
Enter your Xactly Connect account username provided by the Xactly Connect support team. |
Client ID * |
Enter your client ID provided by the Xactly Connect support team. |
Password * |
Enter your Xactly Connect account username. Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
