RingCentral is a cloud communications platform that lets businesses send and receive calls or texts across multiple devices.
If you want to connect to the Contact center API, Celigo recommends using the Nice CXone connector.
API type * |
Choose your RingCentral API type:
Environment * |
Select your RingCentral account environment type:
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided by RingCentral.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Sign in to your RingCentral developer account.
Navigate to Console > Apps.
Click Create app, select REST API app, and click Next.
Enter an App name and integrator.io Redirect URI.
For NA: paste
https://integrator.io/connection/oauth2callback -
For EU: paste
https://eu․integrator.io/connection/oauth2callback
Click Create. You will be navigated to the app dashboard.
Copy the Client ID and Client secret.
Product type * |
Select your RingCentral CX product type (either Digital or Voice). |
Account name * (This setting is visible only when you select the Digital product type) |
Enter your RingCentral account name (subdomain). |
Platform hostname * (This setting is visible only when you select the Digital product type) |
Enter your RingCentral platform hostname (domain). |
Token * |
Enter your RingCentral account token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Insructions |
Auth type * |
Choose your RingCentral authentication type (either OAuth 2.0 or Token). |
Token * |
Enter your RingCentral token. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s token safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
