Adyen is a payment platform that provides businesses with a seamless and unified solution for accepting payments across various channels. Known for its flexibility and scalability, Adyen facilitates secure transactions and supports multiple payment methods, making it a preferred choice for e-commerce and retail enterprises.
API type * |
Choose your Adyen account API type:
Common settings for all API types |
Auth type * |
Choose the authentication type, either Basic or Token depending on the Adyen authentication type you're connecting to. The settings then become specific to the selected authentication type. |
Username * |
Enter your Adyen API username. |
Password * |
Enter your Adyen API password. Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Token * |
Enter your Adyen token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
The following settings are visible only for the Online payments and Platform and financial products API types |
Services * |
Select the required Adyen API service. |
Version * |
Enter the API version. For detailed information, see API version . |
The following settings are visible only for the In-person payments API type |
Company account * |
Enter your Adyen company account. |
Sign in to your Adyen account.
Navigate to Developers > API credentials.
Click Create new credential.
Select Web app and click Next.
In Credential type, select Web service user.
Click Create credential. The Configure API credential page opens.
From General settings, copy the Username.
Navigate to Server settings > Authentication > Basic auth.
Copy the Password.
To retrieve the token:
Navigate to Server settings > Authentication > API key.
Copy the API key (token).
How to retrieve the company account
Navigate to Settings > Account settings > Company settings.
Copy the Company account.
