Contentstack is a leading headless content management system (CMS) that enables businesses to create, manage, and deliver digital content across various channels and devices.
{{a name=quick-ref}}
API type * |
Choose your Contentstack account API type:
Environment * |
Select your Contentstack environment:
API key * |
Enter your Contentstack API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
API type: Content delivery API |
Delivery token * |
Enter your Contentstack delivery token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
API type: Content management API |
Auth token * |
Enter your Contentstack auth token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. How to retrieve the auth token |
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see basic universal connector documentation.
How to retrieve the API key and delivery token
Sign in to your Contentstack account.
Navigate to Settings > Tokens > Delivery tokens.
Click + Delivery token. For detailed information, see Create a delivery token.
Enter a Name and Description.
Select Scopes and Publishing environment.
Toggle on Preview token.
Click Generate token.
Copy the StackAPI key.
Copy the Delivery token.
Navigate to User session > Login to your account.
Copy the Auth token. For detailed information, see Authentication tokens.
