Couchbase Capella is a next-generation cloud database platform designed to simplify and accelerate application development, offering flexible data modeling, real-time analytics, and scalable performance.
API key * |
Enter your Couchbase Capella API key . Multiple layers of protection, including AES 256 encryption, are in place to keep your key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Couchbase Capella portal.
Navigate to Settings > Security > API keys.
Click + Generatekey.
Enter a Key name.
Click Generate key.
Copy the API key .
