Set up a connection to Hugging Face
Hugging Face is a leading platform for natural language processing (NLP) that offers a comprehensive library of pre-trained models and tools, fostering innovation in AI research and development. It's known for its user-friendly interface and extensive resources, making it a go-to hub for the NLP and machine learning community.
Setting Instructions
Name your connection * Enter a clear and distinguishable name.
Namespace *
Enter your Hugging Face username (Namespace).
Fetch data How to retrieve the username
Token *
Enter your Hugging Face token.
Fetch data How to retrieve token
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token auth universal connector documentation.
  1. Sign in to your Hugging Face account.
  2. Navigate to Avatar > Settings > Account.
  3. Copy the Username.
  2. After the first sign in, create an endpoint. For detailed information,
    see How to create endpoint.
  3. Navigate to Avatar > Settings > Access tokens.
  4. Click New token.
  5. Enter a Name and select a Role.
  6. Click Generate a token.
  7. Copy the Token.
Additional references
Was this article helpful?
0 out of 0 found this helpful
