Set up a connection to Notion
Notion is a note-taking web application that offers organizational tools, including task management, project tracking, to-do lists, and bookmarking.
Setting
Instructions
Name your connection *
Notion version *
Enter your Notion API version. For more information, see Versioning.
Token*
Enter your Notion token.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s token safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
dataLoad.svg​​ How to retrieve the token
  1. Sign in to your Notion account.
  2. Navigate to the Integration dashboard.
  3. Click + New integration.
  4. Select the Associated workspace.
  5. Enter a Name and click Submit.
  6. Navigate to Secret.
  7. Click Show and copy the Secret. For more information, see Authorization.
Additional references
