Anthropic is an artificial intelligence research and safety company focuses on building reliable, interpretable, and steerable AI systems.
API key* |
Enter your Anthropic API key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Anthropic account.
Navigate to Profile > Menu > API keys.
Click Create new API key.
Copy the API key.
