Available Corrigo Pro APIs
When you configure an export, import, other type of flow step using the prebuilt Corrigo Pro connector, you can select any of the API operations listed below, organized by API type.
If your API endpoint isn’t listed here, switch the flow step to HTTP mode and configure the endpoint provided in the Corrigo Pro API documentation. You can also create a composite endpoint for this application in HTTP mode.
Resource
API endpoint
Export
Import
Associates
Retrieve associates
X
List of attachments
X
Update attachments
X
Create attachments
X
Delete attachments
X
Download files
X
Bulk
Accept work orders
X
Reject work orders
X
Assign associates
X
Unassign associates
X
Checklist
Get checklist
X
Update checklist
X
Customer
Get the list of customers
X
Retrieve customer settings
X
Retrieve custom field settings
X
Equipment
Retrieve a list of equipment assets
X
Modify a piece of equipment
X
Add a new piece of equipment
X
Delete a piece of equipment
X
Retrieve a list of available equipment assets
X
Retrieve the current state of a particular piece of equipment
X
Review the history of the equipment
X
Health
Get health
X
Heartbeat
Get a heartbeat health check
X
Invoice
Retrieve invoices
X
Update invoice
X
Delete invoice information
X
Submit invoice
X
Recall invoice
X
Work with line items
X
Get invoice attachments
X
Update invoice attachments
X
Create invoice attachments
X
Delete invoice attachments
X
Get a temporary link to a file attached to an invoice
X
Locations
Get all locations
X
Message
Retrieve messages
X
Send a message
X
Search list of messages
X
Priorities
Get all priorities
X
Procedure
Get all procedures
X
Get procedure steps
X
Update procedure steps
X
Get procedure steps attachments
X
Create procedure steps attachments
X
Delete procedure steps attachments
X
Get procedure steps tasks
X
Create the corrective work order
X
Mark a specific procedure as not applicable
X
Get a temporary link to a file attached to a step
X
Required document
Get a list of required documents added to a work order
X
Update the required document details
X
Create the required document details
X
Delete the required document details
X
Get a temporary link to a file attached to a required document
X
Specialties
Get all specialties
X
Work order
Get a list of work orders
X
Search for work orders
X
Accept work orders
X
Reject work orders
X
Reopen work orders
X
Submit a quote
X
Recall a quote
X
Perform a check-in
X
Pause a work order
X
Check out a work order
X
Update the completed work order details
X
Update the work order appointment info
X
Retrieve the history of the internal note field
X
Update the internal note field
X
Update custom field values
X
Get a custom field history
X
Get induction and safety management settings
X
