NuORDER is a B2B e-commerce platform that facilitates wholesale transactions between brands and retailers.
Consumer key * |
Enter your NuORDER consumer key. |
Consumer secret * |
Enter your NuORDER consumer secret. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s consumer secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Access token * |
Enter your NuORDER access token. Multiple layers of protection, including AES 256 encryption, are in place to keep your access token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Token secret * |
Enter your NuORDER token secret. Multiple layers of protection, including AES 256 encryption, are in place to keep your token secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see OAuth 1.0 auth universal connector documentation.
Sign in to your NuORDER admin account.
Navigate to Settings > API management.
Copy the Consumer key.
Copy the Consumer secret.
From the Approved application section, copy the Token (Access token) and Token secret. For detailed information, see NuORDER API documentation.
