Available Salesforce B2B Commerce and D2C Commerce APIs (Salesforce Order Management)
When you configure an export, import, or other type of flow step using the prebuilt Salesforce B2B Commerce and D2C Commerce connector, you can select any of the API operations listed below*, organized by API type.
If your API endpoint isn’t listed here, switch the flow step to HTTP mode and configure the endpoint provided in the Salesforce B2B Commerce and D2C Commerce API documentation. *You can also create a composite endpoint for this application in HTTP mode.
Resource
API endpoint
Export
Import
Carts
Get the items in a cart
X
Delete cart
X
Create a cart
X
Add item to the cart
X
Checkouts
Get checkout
X
Create or start checkout
X
Update checkout with the shipping address
X
Create a payment
X
Update checkout with payment
X
Place an order for a commerce store checkout
X
Products
Search products by search term
X
Get product
X
Address management
Get shipping address
X
Add shipping address
X
Update shipping address
X
Orders
Get order summaries
X
Query to fetch the buyer account ID and webstore ID
X
Was this article helpful?
0 out of 0 found this helpful
