Salesforce B2C Commerce is part of the Salesforce Commerce Cloud suite and is designed for businesses engaged in B2C transactions. This platform is tailored to meet the needs of companies that sell products or services directly to individual consumers.
Short code * |
Enter your Salesforce B2C Commerce short code. |
Organization ID * |
Enter your Salesforce B2C Commerce organization ID. |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided by Salesforce.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( |
Realm ID * |
Enter your Salesforce B2C Commerce realm ID. For example, if your organization ID is |
Instance ID * |
Enter your Salesforce B2C Commerce instance ID. For example, if your organization ID is |
Scopes * |
Scopes are OAuth 2.0 permissions that Salesforce defines to limit access to your account. |
Sign in to your Salesforce Commerce Cloud account with manager credentials.
Navigate to Administration > Site development > Salesforce Commerce API settings. For more information, see Configuration values.
Click Request short code.
Copy the Short code.
Copy the Organization ID.
Navigate to API client. For detailed information, see Create an API client.
Copy the Client ID .
The password that you enter while creating the API client is your client secret.
In Redirect URL , copy and paste the URI mentioned below depending on your instance:
For NA: paste
https://integrator.io/connection/oauth2callback -
For EU: paste
https://eu․integrator.io/connection/oauth2callback
