Set up a connection to X-Cart
X-Cart is an e-commerce platform that provides businesses with a solution to build and manage online stores.
Setting Instructions
Name your connection *
X-Cart path * Enter your X-Cart account path. For example, if your X-Cart account URL is https://celigo/api/products/1, then https://celigo is your path. For more information, see Installing and configuring REST API.
API key*
Enter your X-Cart API key.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this value again; it is stored only when the connection is saved and never displayed as text.
How to retrieve the API key
  1. Sign in to your X-Cart account.
  2. Navigate to the REST API module > Settings.
  3. Select the required API key (Read/write or Only read).
  4. Enter a Name.
  5. Click Submit.
  6. Copy the API key.
Additional references
