Retently is a customer experience management tool that allows you to send NPS, CSAT, and CES surveys to your clients and start gathering, analyzing, and acting on the received customer feedback.
Setting | Instructions |
Name your connection * | Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections in your account. |
API key * |
Enter your Retently API key. |
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see Custom auth universal connector documentation.
How to retrieve the API key
- Sign in to your Retently account.
- Navigate to Settings > API keys.
- Click Generate new API token.
- Enter an API token name.
- Click Generate API token.
- Copy the API token.
