Smile.io is a leading customer loyalty platform that enables businesses to create engaging rewards programs and loyalty campaigns to drive customer retention and engagement.
Setting | Instructions |
Name your connection * | Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections in your account. |
API key * |
Enter your Smile.io API key. |
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token universal connector documentation.
- Sign in to your Smile.io account.
- Navigate to Settings > Platform.
- Select the application.
- Click Show more.
- Copy the Private key.
