Set up a connection to Pigment
Pigment is a financial planning and analysis tool that enables you to identify opportunities, build accurate plans, and forecast your business in real time.
Setting Instructions
Name your connection * Enter a clear and distinguishable name.
API type *
Choose your Pigment account API type:
  • Export: Get metric, list, and table block export details
  • Import: Get status and data to block import details
  • Audit logs: Get monitoring and track audit details
  • SCIM: Get user activity data details
API type: Export
View ID *
Enter your Pigment export view ID.  For detailed information on how to retrieve the view ID, see Export data from Pigment with APIs.
API key *
Enter your Pigment export API key.
Fetch data How to retrieve the API key
API type: Import
Import ID *
Enter your Pigment import ID. For detailed information on how to retrieve the import ID, see Create access signature.
API key *
Enter your Pigment import API key.
API type: Audit logs
API key *
Enter your Pigment audit logs API key.
API type: SCIM
API key *
Enter your Pigment SCIM API key.
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token universal connector documentation.
  1. Sign in to your Pigment account.
  2. Navigate to Workspace settings > API keys.
  3. Click + Create API key.
  4. Enter a Name and choose an Expiration date.
  5. Select Export as Key type.
  6. Click Generate.
  7. Copy the API key. For more information, see API keys.
  5. Select Import as Key type.
  6. Click Generate.
  5. Select Audit logs as Key type.
  6. Click Generate.
  1. Sign in to your Bloomreach account.
  2. Navigate to Settings > Members > Identity and provisioning settings.
  3. Make sure the Single sign-on is enabled.
  4. Toggle on the SCIM provisioning.
  5. Click + Add token.
  6. Choose an Expiration date.
  7. Copy the API token. For more information, see Generate an API token.
Additional references
