Bluecore is an AI-powered retail marketing platform that helps brands personalize customer interactions across email, website, and advertising channels.
Setting | Instructions |
Name your connection * | Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections in your account. |
Namespace * |
Enter your Bluecore namespace provided by the Bluecore product support team. |
Conversation ID * |
Enter your Bluecore conversation ID provided by the Bluecore product support team. |
API key * |
Enter your Bluecore API key provided by the Bluecore product support team. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token universal connector documentation.
