Okendo is a customer marketing platform that helps you drive revenue by turning shoppers into superfans.
API type * |
Choose your Okendo account API type:
API type: Merchant |
User ID * |
Enter your Okendo app user ID. |
API key * |
Enter your Okendo app API key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
API type: Storefront |
Username * |
Enter your Okendo account username. |
Password * |
Enter your Okendo account password. Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see Basic auth universal connector documentation.
Sign in to your Okendo account.
Navigate to Settings > Integrations > Credentials.
Select your Okendo app.
Copy the User ID.
Copy the API key.
