Set up a connection to Treasure Data
Treasure Data is a customer data platform (CDP) pioneer that enables companies to collect, store, and analyze large amounts of data from various sources in real-time. It helps businesses gain insights into their customer behavior, preferences, and engagement patterns by consolidating data into a single, unified view.
Setting Instructions
Name your connection * Enter a clear and distinguishable name.
API type *
Choose your Treasure Data account API type:
  • Treasure Data: Get database, table, job, access control policy, user, and connection details
  • Audience: Get activation, schedule, parent segment configuration, folder, and segment details
  • Postback: Get postback custom webhook data details
Region *
Select your Treasure Data account region.
API key *
Enter your Treasure Data API key.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this key again; it is stored only when the connection is saved and never displayed as text.
Fetch data How to retrieve the API key
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token auth universal connector documentation.
  1. Sign in to your Treasure Data account.
  2. Navigate to Profile > My settings > API keys.
  3. Copy the API key. For more information, see API keys.
Additional references
