Algolia is a powerful search-as-a-service platform that offers lightning-fast and customizable search functionality for websites and applications.
API type * |
Select your Algolia account API type:
API types: A/B testing, Personalization, Query suggestions, and Ingestion |
Region * |
Select your Algolia account region (either US or EU). |
Application ID * |
Enter your Algolia application ID. |
API key * |
Enter your Algolia API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
API type: Analytics |
Region * |
Application ID * |
API key * |
Index name * |
Enter your Algolia index name. |
API type: Crawler |
User ID * |
Enter your user ID, which can be found in the Crawler User settings. |
API key * |
API types: Insights, Monitoring, and Usage |
Application ID * |
API key * |
API type: Search |
Subdomain * |
Enter your Algolia account subdomain. For example, if your URL is |
Application ID * |
API key * |
Sign in to your Algolia account.
Navigate to Settings > Team and access > API keys > Your API keys.
Copy the Application ID.
Navigate to Dashboard > Search. For more information, see Index name.
Copy the Index which is next to the Application.
