Set up a connection to Credly
Credly is a leading digital credentialing platform that enables organizations to recognize and validate individuals' skills and achievements through digital badges and certifications.
Setting
Instructions
Name your connection *
Environment *
Choose your Credly account environment:
  • Production: if your account URL is https://api.credly.com.
  • Sandbox: if your account URL is https://sandbox-api.credly.com.
Auth type *
Select your Credly authentication type (either Custom or OAuth 2.0).
Auth type: OAuth 2.0
Client ID *
Enter your Credly client ID provided by the Credly product support team. For more information, see Authentication.
Client secret *
Enter your Credly client secret provided by the Credly product support team. For more information, see Authentication.
Multiple layers of protection, including AES 256 encryption, are in place to keep your client secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Auth type: Custom
Authorization token *
Enter your Credly authorization token.
How to retrieve the authorization token
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see custom universal connector documentation respectively.
  1. Sign in to your Credly account.
  2. Navigate to Organization > Developers > Authorizationtokens.
  3. Click Add Token.
  4. Enter a Name and click Save.
  5. Copy the Authorization token.
Additional references
