Set up a connection to Salesloft
Salesloft is a leading sales engagement platform that helps sales teams streamline their workflows and enhance their interactions with prospects through automation and analytics.
Setting
Instructions
Name your connection *
Auth type *
Select your Salesloft account authentication type (Token or OAuth 2.0)
Auth type: Token
API key *
Enter your Salesloft API key.
 How to retrieve the API key
Auth type: OAuth 2.0
OAuth 2.0
client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by SalesLoft.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( ) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token universal connector documentation respectively.
  1. Sign in to your Salesloft account.
  2. Navigate to Your applications > OAuth applications > Create new.
  3. Enter a Name. For more information, see Authentication.
  4. Enter the integrator.io Redirect URL.
  5. Choose the Application type.
  6. Select the Scopes.
  7. Click Save.
  8. Copy the Application ID (client ID).
  9. Copy the Secret (client secret).
  4. Click Submit.
  5. Copy the API key.
