Monitor EDI X12 flows and documents
The EDI activity dashboard lets EDI admins centrally monitor and manage X12 and EDIFACT data processing across all integration tiles in your integrator.io account. Use this dashboard to track flow performance, monitor functional acknowledgment (FA) statuses, and resolve processing errors in real time.
The EDI activity dashboard is only available at the account level (Home → Dashboards → EDI activity. If you click the Dashboard tab within an EDI integration, it doesn't show the EDI activity. That is, it is not available at the integration level.
Before you can monitor EDI activities, ensure you meet the following requirements:
Prerequisites
  • Subscription: You must have a valid B2B Manager subscription.
  • Permissions: You must have Admin or Manage All permissions to view account-level dashboard data.
  • Configuration: Only completed flows with an assigned EDI profile appear in the dashboard.
Dashboard – Access point to EDI activity in the account
To access your EDI data, go to Dashboard → EDI activity. The dashboard displays 100 records per page and is divided into two views: Documents and Flows.
Monitor EDI X12 documents
The Documents view is the default view for the EDI activity tab. It provides transaction-level details for every EDI file processed, including information from functional acknowledgment (FA) generation or reconciliation flows.
Document field reference
Field
Description
Doc no.
A unique identifier for the processed document (for example, PO123456789).
MDN status
The Message Disposition Notification (MDN) status or the electronic return receipt sent in an AS2 (Applicability Statement 2) transaction. The column shows Sent or Received only for AS2 Trading Partner or VAN export or import steps.
  • Exports (inbound): Shows Sent for only successful transactions
  • Imports (outbound): Shows Received for successful and unsuccessful transactions. You can click Actions → MDN activity log  and view the details.
Doc type
The 3-digit code for the transaction type (for example, 810 for Invoices or 850 for Purchase Orders).
FA status
The Functional Acknowledgment (FA) status. See the FA statuses table below.
File type
The standardized X12 format used for the exchange.
Direction
Indicates if a transaction is Inbound (received by ERP) or Outbound (sent from ERP).
Processed
The date and time the EDI transaction was processed.
ISA no.
The interchange control number for the transmission.
GS no.
The group control number for related transaction sets.
ST no.
The transaction set control number for each document in a group.
ISA sender
The identifier for the entity sending the EDI interchange.
ISA receiver
The identifier for the entity receiving the EDI interchange.
GS sender
The identifier for the party receiving a specific group of messages.
GS receiver
The identifier for the party originating a specific group of messages.
FA details
Confirmation details indicating if the document batch was accepted or rejected based on syntax validation.
Actions
For EDI flows & EDI acknowledgment flows, select an option below to view transaction details.
  • Download EDI file for completed EDI flows.
  • MDN activity log for only AS2 flows when the MDN status shows either as Sent or Received. The option shows for successful processed exports/imports. For imports, it also shows for unsuccessfully processed MDNs, that is, received but with errors, warnings, or failure. Check the title of the MDN activity log and read through the status message to get visbility into the issue and resolve it.
  • Download ack for completed acknowledgment flows. The option is not shown when Ack status is Failed, In progress, Not Applicable, or Not Received.
FA statuses
Status
Description
Accepted
Document parsed successfully with no errors.
Accepted with errors
Document parsed successfully but contains non-critical errors.
Rejected
Document failed to parse; an acknowledgment was generated with a rejection reason.
Failed
The flow failed and could not generate a functional acknowledgment.
Not Applicable
The Send functional acknowledgement box is unchecked in the export configuration.
In Progress
A functional acknowledgment flow is currently running.
Not Received
A reconciliation flow is expecting an acknowledgment that has not arrived.
Customize the document view
You can customize the Documents view to show only the data you need. Your selections persist across sign-in sessions.
Customize column view
  1. Click the customize button (customize-edi-dashboard.png).
  2. Check the boxes next to the columns to include in your view.
  3. Drag and drop any column to reorder it.
Search, filter, or download documents
  • Filter: Use the Filter By option to select multiple criteria. Select Apply to update the list. You can save these filters for future use.
  • Search: Use the search box to search by Document number, Interchange sender ID, or Interchange receiver ID. The box accepts string data up to 30 characters and supports a single wildcard (for example, PO123*).
  • Download CSV: Select the download icon to save the transaction summary for the selected date range as a CSV file. This does not include EDI files or any filters.
The Flows view displays account-level activity for your EDI integrations. This view only includes completed flow runs. To access this view, select Flows from the view dropdown menu.
Flow field reference
Field
Description
Integration
The name of the integration containing the flows that ran.
Flows
The name of the flows that ran.
Open errors
The count of unresolved errors. Select the count to view the steps where errors occurred and identify if they are from the sender or receiver.
Last open error
The timestamp for the most recent error. Timestamps follow your account profile date/time format settings.
Last run
The timestamp for the last flow run.
Total flow runs
The number of times the flow ran for the selected date range.
Avg run time
The average duration from execution to completion, including queue time.
Success
The number of successful records.
Ignored
The number of ignored records.
Errors
The total count of open and resolved errors.
Auto-resolved
The number of errors automatically resolved by matching a trace key.
User-resolved
The number of errors manually resolved by a user.
Pages
The pages of records processed. For prebuilt Celigo EDI trading partner connectors, these are configured automatically.
Actions
Select Edit flow to modify the configuration or Run flow to execute the flow again.
Filter and search flows
You can refine the list of flows using these criteria:
  • Time period: Select the calendar icon to change the date range. The default is Last 24 hours.
  • Application: Use the Select application menu to filter flows by a specific connected app.
