You can connect to your Amazon Aurora PostgreSQL database (DB) cluster using the Celigo PostgreSQL DB connection. First, connect to the cluster endpoint, then read (export) or write (import) data as required.
See also,
Before you set up the PostgreSQL DB connection, keep values for these specific Amazon Aurora PostgreSQL DB cluster settings ready.
Now, use these details and set up a PostgreSQL DB connection to your Amazon Aurora PostgreSQL DB cluster.
After you connect to your Amazon Aurora PostgreSQL DB cluster, run any SQL command that is compatible with PostgreSQL in your exports or imports.
